Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I was looking for a good buy on a 5770 and found this on newegg. I can power it and Cpu is adaquate. Is this a good buy or should I wait for 5770 on sale? $109 seems good.
Thanks to all.
Alot of those Sapphire 5830s can hit 1Ghz core which puts you at 5850 performance levels... Until you start cranking the AA. If you're fine with 4xAA or less(usually less) Definitely get the 5830. You can find 768 460s for a similar price too, if you're looking for options.
