Sanyo Denki Mod
coolchu001
I just got a Sanyo Denki CPU liquid cooler from frozencpu.com and I was wondering if anyone else has one. It seems like I need to cut out a top vent hole for the radiator and also make some custom brackets.
BTW these are the same water cooling kits that Falcon-NW uses.
I haven't gotten it installed since its hard to fit it into my Lian Li PC-V1000 but I just got 2 new Cooler Master ATC-710 and the sanyo fits without having to cut the sanyo's mounting bracket holes, I just need to find time to cut out a top vent on the ATC-710.
