Sansa Clip+ MICROSD Card, What Class?
I'm looking to get a 16gb microSD card to upgrade the memory on my 4gb Sansa Clip+.
I looked into cards, and there are 2, 4, and 6 class cards (with greatly varying prices). From what I know the class affects write speed.
I don't care how long it takes to write, but will playback be slower or sluggish on a slower (class 2) than on a class 6 card? I want to get a card that is cheap but I can't stand sluggish performance/playback. Does anyone have experience with 16gb microsd cards in the Sansa Clip + and how is the performance using these.
There will be zero differences between any of those cards regarding playback.
Yep, I have the clip+ and a class2 and a class6 microSD card. No difference between the two.
If write speeds aren't a priority, then the class2 should be fine.
The Sansa Clip + writes internally at class 4 speed, or 4 MByte/s. Amazing sounding and powerful little player by the way.
Thanks so much for the responses everyone, just have one more clarification:
Since the Clip+ is internally 4 MByte/s, will performance (and by that I mean things like playback, browsing through songs etc) be slightly worse on a full 16gb class 2 card?
Or are these all just write times, meaning there will be no difference in performance?
I don't think you understand. You could have the slowest possible card they make and playback/browsing through songs would not be affected. The speeds of these cards will never affect any of that.
