As a 9550 user this isn't enough for me yet, I figure I can sit tight for at least another year and a half. The real target I'm looking for is probably the hex and octo variants. That and go from 8GB to maybe 16~24GB.
I want it, socket 2011 or go home![]()
what part of unlocked multipliers on K series parts doesnt explain itself...
"First and foremost we have the K-series parts. These will be fully unlocked, supporting multipliers up to 57x. Sandy Bridge should have more attractive K SKUs than what weve seen to date. The Core i7 2600 and 2500 will both be available as a K-edition. The former should be priced around $562 and the latter at $205 if we go off of current pricing"
I keep seeing people post similar comments about overclocking. Probably have to repeat it about 15~20 times before some people start to understand.
Lord can't they come up with some new names. Sheesh. i3, i5, i7, i9 again? for a completely different architecture too?
If the K-series parts are priced appropriately, which at first indication it seems they will be, then this will be a non-issue for a portion of the enthusiast market. You’ll pay the same amount for your Core i7 2500K as you would for a Core i5 750 and you’ll have the same overclocking potential.
There's no new information on Sandy Bridge overclocking at this point (although it's looking increasingly likely that there will be a reasonably priced K-series SKU for those users who want the flexibility to overclock without spending $1000).
I don't think unlocked i7's are going to be $500, unless their locked varients come in at $450-480 in which case the extra $20-30 is well worth it.
"think"
Well Anands guess was that the i5 is going to be around $200ish, and the i7 around $500 from the post on the first page![]()
I read somewhere that Intel's partners and OEM's didnt want another naming change to "confuse" customers. So they kept i3, 5, and 7.
I think its dumb, but w/e. Customers who get confused are just zombie zealots anyway, so who cares about them.
maybe they should have been the i4, i6, and i8.![]()
"think"
Finally, if you focus on multiplier-only overclocking you lose the ability to increase memory bandwidth as you increase CPU clock speed. The faster your CPU, the more data it needs and thus the faster your memory subsystem needs to be in order to scale well. As a result, on P67 motherboards youll be able to adjust your memory ratios to support up to DDR3-2133.
4900MHz on a stock cooler?
http://www.fudzilla.com/processors/processors/processors/intel-overclocks-sandy-to-49ghz
Yep. Once they hit the stores, if reviewers buy random test samples and if it performs similarly, then I would be impressed.I'm going to guess that it was a hand picked cpu that was among the very best (overclockers). I think that if the average Joe could do 4~4.5GHz on a stock cooler most people would be very pleased.
Anybody know if there will be variants of SB that do not have the GPU on die? I do not plan on using onboard ever so it seems to be a waste of silicon for me.
same here, unfortunantly seems that the Sandy Bridge running on LGA1155 will have GPU.
