Sup Guys.
I just build this rig 2 weeks ago.
Fortron BlueStorm 500Watt
AMD Athlon64 3700+
OCZ EL Platinum Rev2 TCCD 2-2-2-5
DFI Lanparty UT NF4 Ultra-D
EVGA Geforce 7800GT w/copper heatsink
Pioneer DVD-Burner
Zalman CNPS7700-Cu
Currently running at: 1:1 ratio
CPU : 300 x 9 = 2700 mhz @ 1.425 Volt
Ram timing: 2.5-4-3-7 @ 2.9 Volt
Genie BIOS Settings:
FSB Bus Frequency - 300
LDT/FSB Frequency Ration - Auto
CPU/FSB Frequency Ratio - 9
PCI eXpress Frequency - 100Mhz
CPU VID StartUp Value - StartUp
CPU VID Control - 1.425v
CPU VID Special Control - auto
LDT Voltage Control - 1.20v
Chip Set Voltage Control - 1.50v
DRAM Voltage Control - 2.9v
Temperatue: idle 27 celcius, load 37-39 celcius.
I already tried 240 x 12 = 2600 mhz at timing of 2-3-3-5 and its stable. CPU volt is at default, ram is at 2.9 volt.
what do u think? should I go for 2700 or 2600 on tight timing. how can I achieve 2800mhz?
AMD Athlon64 3700+
Pioneer DVD-Burner
Zalman CNPS7700-Cu
