Would this serve as a good PC gaming monitor? It is available at Costco. It looks like a decent HDTV but I also want it for gaming on the PC. Thank you for your time.
Samsung's LN-S2338W
HDTV Ready: For HDTV viewing experience, you must contact your local cable or satellite provider for HDTV services in your area.
Features:
Panel Type: LCD
Resolution: 1280 x 720
Contrast Ratio: 3000:1
Aspect Ratio: 16:9
Viewing Angle: 170º(H)/170º(V)
VESA compatible
Built-in analog tuner (NTSC)
Audio Power: 3W X 2
Bottom Built-in speakers
Power Consumption: 90 Watts
Dimensions:
Monitor w/ stand: 23" W x 19.1" H x 8.1" D
Monitor w/o stand: 23" W x 17.4" H x 3.5" D
Weight: 19 Lbs.
Inputs/ Outputs:
R/F Input: x1
HDMI in: x1
Composite in: x2
Component (Y/Pb/Pr) in: x2
(480i/480p/720p/1080i)
PC input: x1
PC (RGB Input): x1
Headphone jack: x1
Samsung's LN-S2338W
Features:
Panel Type: LCD
Aspect Ratio: 16:9
VESA compatible
Audio Power: 3W X 2
Dimensions:
Weight: 19 Lbs.
Inputs/ Outputs:
R/F Input: x1
HDMI in: x1
Composite in: x2
PC input: x1
PC (RGB Input): x1
Headphone jack: x1
