Afterhourpower
- Nov 19, 2008
I just picked up the XL30, and I cannot say anything other then WOW.
It is a solid display, in the sense that, its as if I am looking at a lightbox with a still image, no flickering... mind you I never really noticed any flicker on my other displays until i got this XL30. I guess our eyes adjust to things, until it has a reference point to mark what is changing vs what is static.
Anyway, I was hoping to calibrate this as I do lots of proofing before printing press. I remember using D55 before for CRT, but the new standards have changed, and D65 is correct for LCD, and then the gamma was something before, but now 2.2 is correct, as far as brightness I am not sure what to target for. i did run the calibration with D65/2.2gama/160cd/m2 (200 is max, and I sit about 20 or so inches from the screen, and when my screen goes to a white mostly area its like the sun is rising all over again)...I will leave at what ever it should be for correct colors black and such, but I dont know what it should be.
Anyone with some input on this? It uses the Xrite LED cal tool with Natural Color Expert 2.
The stand could also be a touch more solid, and it could be specifically made like this, but if you touch the bezel the entire screen does wiggle. not loose but a springy bounce to it...maybe for so safety or?
The colors on this are just like looking at some velvia film on a super bright light box...they are true and RICH.
