killer1022
- Sep 16, 2009
I think they came out yesterday, when looking at which stores carry it, almost all the stores around me have it, I'm in Illinois btw. Gonna pick up 3 today and post pics this weekend.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I think you should return or exchange, sounds defective. Mine views that page with no issues.This is a nice monitor but it is a TN and has all of the issues that plague a TN display. I've been using this one for a couple days now and I think the color is pretty good for a TN. I do have a problem that is a showstopper for me, though.
On mine the backlight is very bright at the bottom of the screen and makes black look almost blue it is so bright. Also it causes detail to be lost as you get close to the bottom of the screen. To give an example of how the backlight washes out the colors at the bottom of my screen, take a look at this NOAA weather link.
http://www.spc.noaa.gov/products/
On my XL2370 I can see four maps on the page. I can't see the state lines at all for the bottom two maps. As I scroll the page I can begin to see the state lines at about the halfway point on the screen. But even on the second map image I can tell the lines aren't as dark as the top one. Only the one on the very top has dark lines. I have to move my head below the display to be able to see the state lines on the bottom two maps, but at that point the top of the screen begins to darken. By comparison, my 15" MacBook Pro with a LED TN panel does not have this problem. It has evenly lit backlighting. On a black screen on the XL2370 I can see that the bottom center of the XL2370 has a large bright spot.
Of course that is something particular to this XL2370 and if I exchange it the next panel could be perfect.
No. Most owners have described the same thing.think if i exchange it ill get lucky and get one without the bleed
think if i exchange it ill get lucky and get one without the bleed? it didnt have this when i first bought it, it slowly developed.
Ok, unless someone can convince me otherwise, I think I'm about to order this.![]()
Thanks for your response.Xiang: That is one of the default settings in the monitor's menu. If you want to fix it, do the following:
1.) Access the monitor's menu on the touch screen buttons (the furthest button on the left)
2.) Go to the SETUP&RESET option
3.) Scroll down to Auto Source and change it from Automatic to Manual (The Auto Source option is on the 2nd page of the menu, so you have to keep scrolling down until it shows up).
that should do it
