Silent Ricochet
- Feb 15, 2008
Looking to grab a good 16:10 display for under $150. I'll be using this display primarily for schoolwork, writing code, and in my spare time playing some decently long sessions of BF4. Right now I'm running a horribly old DCLCD DCL20A+ 20.1" display that has served me very well over the years. I have a TV acting as a 2nd monitor and it's pretty inconvenient, although I really enjoy the multitasking ability of having two monitors.
I'm worried about the performance hit I'd take by moving from 1680 x 1050 to 1920 x 1080... I had a friend, with the same GPU, same settings stand in the same spot on the Test Range on BF4 and he got 30 FPS less than me at 1920 x 1080. That's unacceptable to me. That being said, I'm open to suggestions but I'm really focusing my research on these two monitors listed below. So if you had to choose, which monitor would you get? I know NEC and Samsung both make great displays, and I can't seem to find much on both monitors to warrant choosing one over the other.
NEC Display MultiSync E223W-BK
OR
Samsung S22B420BW
Good color representation and response time are important to me, but I understand If I have to make tweaks, it's part of being a PC owner. My only other concern is the display looking goofy at 22" at 1680 x 1050. Low pixel density? But the concerns aren't really founded in anything factual, I just imagine it looking like running a too small of a resolution on a large monitor.
I am open to suggestions. Please note, I'm really not a huge fan of 16:9 displays, too unnatural and wide looking. So to get a 16:9, you'd have to be pretty convincing.
Thanks in advance,
Silent Ricochet
UPDATE! 10/9/14
After reading the feedback from NCX (thanks!) and doing some research on my own in Battlefield 4 in regards to framerate loss, I decided to go with the 22" version of the 16:9 LG monitor NCX recommended to me.
LG 22MP55HQ-P
The difference between my old monitor and this one is night and day. I really could not be happier. Brighter whites, deeper blacks, and the colors are incredible. I cringe every time I look at my second (old) monitor now. HD movies look insane and BF4 looks amazing. Everything is much clearer, sharper and has more depth and contrast. I know I'm not a fan of 16:9 displays, but this one definitely works because it's the same height as my old 16:10 monitor, so the switch wasn't as shocking or dramatic. I'm extremely happy with this monitor and would highly recommend it to anyone looking for an affordable yet quality 1080p display.
OR
Samsung S22B420BW
Thanks in advance,
Silent Ricochet
UPDATE! 10/9/14
LG 22MP55HQ-P
