SAMSUNG TOC T260HD 26 inch
blert
So has anyone have any experience with one of these? I'm looking to replace an aging 24" HP CRT....
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001281
I'm considering one to use as a gaming monitor. Will only be running one monitor off my system.
The reviews are kind of mixed, but overall positive.
Is there something similar out there without speakers as I'll never use the built in ones on the monitor? I'm trying to keep it at $500 +/-, preferably below.
ANYONE??
I was thinking of this or one of the BenQ 24" models but this has 1X1 pixel mapping as well as the Ben Q models.
The Samsung is larger at 25.5"
The Samsung has a built in HDTV tuner.
The Price difference is around $80
So why aren't more people buying the Samsung?
Am I missing something other than the BenQ is faster at 2ms vs the Samsung at 5ms??
Any replies would be appreciated!!!
ANYONE??
I am looking into getting this monitor/tv as well. I think the reason there isn't too much info on this model is that it is relatively new.
I can give you some secondhand knowledge...
1. It's a TN panel so it should be plenty fast for gaming, though viewing angles will not be as wide as they could be. So, not a great choice for a setting where you are not sitting directly in front of it.
2. The high resolution is great for desktop (close up) setup but is wasted if you are not sitting close to it or are not going to use it as a computer monitor.
3. Samsung has a stellar reputation for making excellent LCD HDTVs, so I am assuming this performs up to their standards.
4. Unsure if this monitor scales 1:1. I think it depends on how you connect it (HDMI, Component, versus VGA) and what your settings are, but I cannot attest first hand. It is a good bet that certain input/setting configs. do, since it is designed for computer AND tv (16:9) resolutions.
5. Cannot mount to wall (no VESA compatibility).
6. Conflicting reports about HDCP support. Some people on the "internets" reported that the HDMI input does not support HDCP, but Samung reported to the tech blogs that it does. I assume it does...not having this would be a HUGE mistake, as you would not be able to watch blu-rays.
Anyway I hope this summary of the gossip on this monitor/tv helps, but if you are still unsure about buying, just wait a couple months till some users have a chance to post some comprehensive reviews.
I am going to pull the trigger in the next couple of weeks on a new monitor, so if I get it I will post a quick review to nail down some specifics for others.
