kanyewest4444220
- Dec 7, 2008
well i just bought it of newegg.com
the first day it worked perfectly,then i was playing bioshock and the screen would turn off and have to restart it so it could work again.
so then i tried to play world of war craft and it did the same thing and it would also flicker or blink.
i was using the DVI connector and i put the VGA connector and the same thing it would turn off.
i put the driver of the monitor to see if that was the problem but no it wasn't that.
so i was just wondering how come it does turn off randomly and flicker or blink?
and thanks for the help
