Samsung Syncmaster 275T RELEASED
Actually I don't think my first monitor was defective afterall now. What I've discovered is there is a bug in Samsung's firmware. If you adjust the gamma setting it doesn't affect the entire screen equally, there is a strip along the right hand side in which blacks will be affected by the gamma setting differently than the rest of the screen. So if you use an extreme gamma setting like +0.6 and then look at a completely black screen you can easily notice it.
Not that big of a deal since pretty much the same effect can be achieved by tweaking the brightness and contrast, but it made me think I had a defective screen.
Does this monitor support 50Hz via DVI? I have read that you can lower the refresh rate with powerstrip to 50Hz that it's more suitable for PAL. Can it be done with this monitor?
