As I stated in my last post, the Samsung 225BW does NOT do 1:1 pixel scaling. There is nothing in the documentation or in the onscreen menu (which I've gone through completely) that hints at any such feature.
So in short, unless you have software via the source (a PC for example) which tells the monitor to do otherwise, it's going to stretch the images to fit the screen. Case in point, my PC scales everything according to the original resolution so they look perfectly normal on screen (a 1024x768 image for example will not stretch to fit the screen) while games on my 360 will ALL stretch to fit the screen. Again, it isn't even noticable though and this is coming from someone who was very concerned about that before buying the monitor.
Update BTW, my wife convinced me to not return the monitor and now I'm glad I didn't. After some additional tinkering I found good color settings on the monitor for my 360. Besides, the PC games just look insanely better on this monitor than my 19" CRT anyway.
I'll see if I can post some pics in the next day or so to show you guys.
