by the WD5000KS Not bad for a 500GB four platter drive.
http://www.silentpcreview.com/article617-page1.html
SPCR had to double check their measurements the power and noise measurements in AAM mode were so jaw droppingly low. Still suffers from a little bit of vibration, but grommets should pretty well mitigate that. Both motor and seek noise are inaudible from one meter and out.
8.5W at idle, 8.6W seek in max AAM mode. Incredible that a 500GB drive with four platters is quieter and cooler than a single two platter 250GB Samsung drive, let alone the two that it would take to match the 5000's capacity. And oh yeh, almost forgot, the WD5000KS kills the Samsung drives on performance too
Add to this that you can score a WD5000KS on ZZF for about $220, and there's a new PVR/HTPC drive of choice.
All of you haters that think WD is "just a marketing company" need to sit up and take notice
