haste
- Sep 27, 2005
Is this 7200.11?
not bad for 1 per GB.
http://www.bit-tech.net/hardware/2008/12/09/samsung-spinpoint-f1-1tb/1As well as 1TB, the Samsung Spinpoint F1 is also available in 750GB, 640GB, 500GB, and 320GB flavours too, and rather strangely, uses the same 334GB platters in every disk. This seems an odd choice, especially when you consider the wasted storage physically there is no difference between the 750GB and 1TB versions of the Samsung F1 other than the different amount of unlocked drive space per platter.
