Is this what you call shimmering or what?
Watch the video. Start at about 13 seconds and look at the links/text shimmering/whatever you call it. This is not something the camera is producing, this is what it actually looks like on my screen. What should I try to fix this?
This is from a samsung LNT-4069
Start at 13 seconds. http://www.youtube.com/watch?v=2ORdv4HEeTU
EDIT: Ok, I moved some power cables and theres no power cable within 10 inches from my DVI cable. But the problem is still there.
Also I noticed a major factor is the problem ONLY happens if I have a movie playing at the same time. I can start a movie and the problem comes and goes when surfing etc. But soon as I stop the movie, I have yet to see the problem.
Any suggestions?
Also whats the best way to cover wires, should I get some cheap wire loom. Like these http://cableorganizer.com/wire-loom/colored.html ?
Any suggestions?
