p3sty
- Feb 22, 2006
Any thoughts on this and what exactly is 165 htz motion blurr technology?
To drag an ancient annoyance of mine out from the dusty cupboard, I have to wonder if the 43" panel used in the QN90F series has finally gotten rid of that awful pixel interference issue that made me stop using the FV43U and move to the 50" QN90A. I'm still using it and it's going strong but I wouldn't complain in the slightest if I could get the same visual quality at 43" rather than the desk-consuming 50"!
Good information. Didn't know that the smaller sizes didn't have HDR+ although from these notes seems like the 43 does retain HDR+ ? The cart is a little weirdBe careful when shopping for these kinds of screens because the smaller variants sometimes have different screen tech.
This is the breakdown for the QN90F, at least according the RTings:
"The two smaller models have fewer speakers (20W 2 channels on the 43-inch, 40W 2.2 channels on the 50-inch), and have Neo Quantum HDR instead of Neo Quantum HDR+, which means that they're likely not as bright or as colorful as the bigger models. "
Size US Model Short Model Code Costco Variant........................Neo Quantum HDR+
43" QN43QN90FAFXZA QN43QN90F - No 20W, 2.0................. NO
50" QN50QN90FAFXZA QN50QN90F - No 40W, 2.2................. NO
55" QN55QN90FAFXZA QN55QN90F - Yes 60W, 4.2.2.............YES
65" QN65QN90FAFXZA QN65QN90F QN65QN90FDFXZA.......Yes
75" QN75QN90FAFXZA QN75QN90F QN75QN90FDFXZA.......Yes
85" QN85QN90FAFXZA QN85QN90F QN85QN90FDFXZA.......Yes
98" QN98QN90FAFXZA QN98QN90F -.......................................Yes
Per Google search:
Feature
Neo Quantum HDR+ (QN90F)......................................................................................................................Neo Quantum HDR
Brightness Up to two times brighter than Neo Quantum HDR, delivering superb brightness............................ Less bright than Neo Quantum HDR+.
Dynamic Range Dynamically adaptive scenes and a higher dynamic range. ...................................................Standard HDR experience.
Processing Uses AI-based Auto HDR Remastering Pro to enhance highlights and details...............................Standard HDR processing.
Performance A more vivid and premium HDR experience..................................................................................Less vivid and premium than Neo Quantum HDR+.
Also , abraded/matte screen can be a compromise depending on your sensibilities and eye for detail.
If you order from Amazon it's a free return they have the best return policy no questions asked just return it if you wanna try it. I just get the 50" and run it in ultra widescreen 3840x1600 it's so sweet.To drag an ancient annoyance of mine out from the dusty cupboard, I have to wonder if the 43" panel used in the QN90F series has finally gotten rid of that awful pixel interference issue that made me stop using the FV43U and move to the 50" QN90A. I'm still using it and it's going strong but I wouldn't complain in the slightest if I could get the same visual quality at 43" rather than the desk-consuming 50"!
