Since you have to setup pairing to the monitor. Does this means only one active glasses can be used at a time? Can two people wear two glasses at the same time? Does the Nivda 3D have this limitation? LS23A700 as an example
There seems to be three different versions of 3D glasses for monitors. The SSG-M3150GB, SSG-M3050GB and the rechargeable SSG-M3750CR. Which will give the best performance the SSG-M3150GB or the SSG-M3050GB. Looks like the battery placement is different and frame for the bottom of the glasses. Which is better for people with glasses?
