On a vacation. Was thinking about posting it then. Should have lol!damn where where you a week ago! free bump
I can find out. What's a good software to use?do you know the total writes number?
You can take a screenshot of the main screen after running CrystalDiskInfo software for that. The Samsung Magician software will also show it, in Drive Details area, on the Samsung SSD disk, you may not have to remove it from the enclosure to see that if using the Samsung software. You can also click S.M.A.R.T and do an Export there:I can find out. What's a good software to use?
Sorry for the delay, I had a work project.You can take a screenshot of the main screen after running CrystalDiskInfo software for that.
The Samsung Magician software will also show it, I edited my prior comment to show that. Using Samsung Magician you may not need to remove the drive from the enclosure.
My bad! I didn't see this! Yes it's availableStill available?
