Samsung 955 DF blurring
flurp
Hiya
I bought a Samsung 955df about 3 years ago or so. Recently the left side of the screen began a bit of blurriness, specifically in 2d situations. In games it's fine.
Is there anything that can be done about this or is it time to retire the thing?
Well ya may wnat to call Samsung Technical Support. I dont know how long the warrenty is for that specific monitor but you could always call and Say you have only had it for 2 years. I think they will ask you to bring it to service center
good Luck
i have the exact same monitor and bought it about 3 yrs ago as well.......... however dont have any problems like that. What display settings are you using? have you tried switching around with refresh rates and what not?
