Samsung 941BW Vertical Red Line
pmc255
I purchased the Samsung SyncMaster 941BW from Buy.com, and got it a couple days ago. After about a day of usage, a single-pixel wide red/pink vertical line suddenly showed up in the middle of the screen, extending from top to bottom.
I had just installed a fresh copy of XP, so I thought it might be driver-related. I tried rebooting, and the line was still there during the BIOS boot-up screen, so it didn't appear to be software related. When I turned the monitor on the next morning, the line was still there. However, it vanished after maybe 30 minutes of usage, and hasn't shown up since. It's been almost 2 days now, and I have yet to see it.
I've read through some of the posts regarding vertical lines of "stuck pixels", and most people seem to just RMA it. I couldn't find anyone in my situation though, where the problem came and disappeared and can't be reproduced. What should I do in my situation?
I don't know if/when the problem will come back. I don't really want to deal with returning to Buy.com, as I have already had a horrible experience with them. If anything, I'd RMA with Samsung. Is Samsung's RMA process quick and easy? Do they actually pay for everything?
Nonetheless, I've only had the monitor for about 4 days. I'll use it a few more days before I decided whether or not I should return it, just in case. Any comments or suggestions are highly welcome. Thanks!
BTW, just to give more background (if it helps), I'm running:
Windows XP SP2
Asus A7V133 w/ AMD Thunderbird 1433mHz
eVGA Geforce 6200 LE AGP
The 941BW is connected via DVI, and I also have a Vizio VX32L LCD TV connected via VGA.
I've installed the latest drivers and have checked the physical connections. I still have yet to see the problem re-occur......
Can anyone help me with this issue? The line hadn't shown up for more than a week, but I just saw it today. It's totally random. Even just a quick reply about whether or not it's worth going through the hassle of Samsung's return is quick/easy, or if I should bother with Buy.com would be great. Thanks!
