Samsung 940b - Good gaming lcd??
qtip
Has anyone had personal experience with this lcd monitor? Im currently looking into the market for a 19" lcd monitor that has: 8ms response time or lower and DVI connection. Since its made by samsung, i figure its build quality will be exceptional. Ive been looking all over the internet for reviews and cant find any. It is on sale at newegg for $389. I play games and watch movies. Any positive or negative comments would help me alot in my decision.
I have the 930B, which looks like similar specs. Its an amazing gaming LCD. The response rate is incredible fast and my friends and roomates at school can hardly beleive its an LCD its so responsive. Just make sure its got a DVI-D interface and that you use it or else you will loose so much.
The color reproduction is a bit off. I first noticed it after booting the first time and the taskbar and webpages that I frequent were a little bit off. This took alot of adjusting but I finally got it to a comfortable setting.
Games are brilliant, from Farcry, to Doom3, to CS:S, to WoW.
Thanks for the input. Im glad to hear that you like it. I checked out the 930b and they do look similar. Ill probably get the 940b though because its a little cheaper. After i pickup my check this weekend ill make the purchase and tell you how it performs. Thanks again. :D
I'd like any info anyone might have as well, since I haven't seen a single review on it and will be purchasing a 19-inch LCD within the next week. So far I had narrowed down my choice, due to budgetary considerations, to the Viewsonic VX924, which I've seen for $359. Reviews on it were quite mixed due to some color issues many reviewers experienced in their tests of a beta version of the monitor. As shown later in an article by Behardware, this was overcome. Otherwise I'd obviously buy the king of the 19-inchers, the VP191b.
At the same price, I've seen the Syncmaster 940b, but not only can I not find a review, I can't even find a user review on it, so it is a completely unknown quantity. It costs on average anywhere between $50-$100 more than the 930b, so I'm not going to presume it is a souped up 930b. I'm going to presume it is using another panel. The big question is which?
Any enlightenment would be very much appreciated.
Cheers,
Albert
I'd get the vp191b if you have the money. It's an 8-bit panel and doesn't have the backlighting issues that the vx924 has. It's also a heckuvalot cheaper than the samsung 193p+.
Cheers,
Albert
Spec sheets say it is still a TN panel...so therefore I must assume the differences are minimal.
:cool:
I have the same monitor but didnt notice any color issues.
Damn, there really are no reviews out there. Heck, I'd get it just to be the first to write one! Anyway, here's the info I've found thus far on different forums and such (aka, not 100% reliable, but just as reliable as any user opinions you might hear from us!
- "The 940B is not using the same panel as the 193P+ unfortunately, it's a TN film panel, the same as that used in the 913N/913B/Hyundai L90D+ etc. Still a very good panel, but that explains the price difference." -overclockers UK
- "http://www.marketingsamsung.com/docs/brocs/940B-Black-ds.pdf" - just some specs
- "The 940B is also 16.2 million colours and not 16.7, there's virtually no difference between the 930 and 940 models." - computermechanics.com
As you said, not much out there. I have the 930b (got an amazing deal on it) and, although it is my first LCD, I can say it made the transition from a 21" Trinitron quite painless (well, except lifting the damned thing! :eek:). The color reproduction is just great for me, although as Menelmarar said, it does need some adjusting (like a CRT doesn't?).
I'd say go for it!
I got the 940B today, using it in portrait mode, it seems the colors look alot better when viewing it from further right, this would equate staring down at it at an angle for a normal person. Anyone else have that?
