Samsung 850 EVO overprovisioning
sblantipodi
Hi,
should I set the 10% over provisioning as suggested by samsung magician?
Is it something really needed?
From what their explanation states it seems like you should set it a bit higher for better access times, assuming you have the disk space to do so. No freaking clue if this would have any real world, noticeable impact. Probably not for normal users and gamers. I would leave it default.
I don't like this from samsung.
Many drives comes just overprovisioned and the "overprovision space" is not considered as storage space.
I bought a 1TB drive and now I need to overprovision it, this means that it is not a 1TB drive.
its has OP already....just not enough. All drives never have enough OP
look at every anandtech review ans you'll see 20-25% more OP is needed on every drive
so, should I add another 10% of overprovisioning or not?
it depends on your work. Do you need consistency? Do you really thrash the drive with 2 hours of straight reading with writes at the same time? If no you probably don't need it but if you notice the drive hanging then yes OP. I had an 840 before the EVO and even with OP that drive would literally hang. My OS would freeze because of my reads and writes. I have to switch to an Extreme Pro with 20-25% OP because my do so much reading and writing at once. I average, which means the read thrashing is much higher than this average keep in mind. I average 350 GB reads a day and 150 GB writes a day and much of that is consolidated. So like I said if you don't notice any issue then don't worry about it. If you notice the drive literally freezing like I have seen then you need to OP a lot more.
I was so pissed when I got the 840 because I never had an OS actually freeze by doing writes and reads when I had a HDD so it was weird and irritating. The extreme Pro didn't have that issue because its a bit more robust of an SSD
CanI ask you want you write to crash the drive like that?
well mix read/write is killer so whenever AV/AM went off (middle of night) and I was still awake using my PC doing stuff it would completely hose itself. OS activity, whatever I was doing (gaming, editing, moving files, browsing, or whatever), Kaspersky, and MBAM all going at the same time would cause my PC to freeze. It was fine on an HDD but with SSD it would just stall. I couldn't move mouse for mins at a time. with OP and upgrading to a better SSD. I never ran into that problem again or exptremely rare I don't even recall.
Fopr whateverr reason kaspersky is just stupidly hard on an SSD. Even now my PC still acts slow when Kaspersky goes off. Whatever that AV does completely wrecks an SSD and add everything else on top of it...well it causes issues. Kaspersky scans take eternity too and its really annoying.
Sounds like you have some additional issues with your system if an AV scan completely thrashes a modern SSD.
Nah its just kaspersky. It is oddly intensive. Nortorn doesn't have that issue but i dont like norton.
Also like i said the issue of hangs disappeared with the Extreme Pro. The drive just gets trashed a lot for whatever reason.
Stupid question, but if you set overprovisioning and then enable RAPID mode; can you then uninstall Samsung Magician and the SDD will retain those configurations?
Reason I ask is that my brother was saying he's noticed issues with his computer hanging/freezing and I suggested he install Magician to update the firmware and set OP and possibly RAPID to see if it resolves the issue.
I have a feeling he wouldn't want to leave it installed long term as he doesn't like to have a lot of random programs on his system.
If you uninstall magician you will retain the OP but not the Rapid.
OP is nothing more than an empty non partitioned space, Rapid requires magician to move data from disk to ram.
Thanks. Will give this info to him along with a few other things to try and troubleshoot with like AHCI mode in BIOS, SATA cable replacement, etc.
For clarity's sake, Samsung Magician doesn't need to be running for RAPID to work. It's best to not have Samsung Magician running at startup, and to only run it when you need to change a setting.
I don't tought so, thanks for clarity.
