samsung 710n?
poddo
2005 [H]orde|Bowl Champion
I'm building a new rig and don't have a monitor. I'm going to be using it for a lot of gaming and LAN parties. I was thinking about going with the samsung 710N. LCD or CRT doesn't matter to me really. I like the slim-ness of LCD, but if the performance in gaming is weaker, then im willing to go with a bulkier CRT. Anyone have any suggestions?
I adore my 712n, which is identical to the 710n but with a different style base. Your eyes will thank you. :D There are actually several reviews of this monitor on the net. Do some googlin'. Also of note is some specs you should be lookin' for. Namely:
xx ms or rt
-this is your response time, the lower the better
-look for 12 or under and you'll be free of ghosting images
nit or brightness
-this is your brightness, the higher the better
-not sure what to recommend, but the sammy's is 300 which seems higher than quite a few
viewing angle
-look at a laptop from an angle and you'll know exactly what this means :mad:
-look for 160+ on both horizontal and vertical
-The sammy's horizontal is great, but the vertical could use a boost if you lower/raise your chair more than 6-12 inches ie. movies or typing
native resolution
-the higher the better, usually
-if you have an lcd with a native res of 1600x1200 and your video card can't pull the mustard you may have to deal with subpar iq...it's not as bad as text tho
contrast ratio
-shoot for 500 or more
-I wish I could explain more...lol!
dead pixels
-they suck...really bad
-it's not just dead pixels, but stuck, open, or whatever they're called.
-for instance, I had a laptop with one blue pixel above the movie widescreen image ie. right on the widescreen bar...I couldn't stop looking at it!
-they have improved dramatically tho...your chances are much better with a Samsung/Viewsonic over a Sceptre/DCL/etc...
They're light and don't give you cancer...good luck!
edit: oh yeah, the samsung has a wonderfull little button on the bottom that changes between 4 different color/contrast/brightness levels. There's custom, text, internet, entertain. I use them for mainly varying brightness/contrast. Starting with custom for no light conditions, text for low light, internet for daylight, and entertain for games/movies. Let me know if you have any questions.
