Samsung 710N Confusion...
BombermanX
As I was browsing lcd monitors on newegg I found a surprising discovery....
A $440 12ms samsung LCD with 600:1 contrast, amazing brightness... however, when I check to make sure that it's not some data entry problem, I get almost completely different specs (From samsung's site) including color, contrast ratio, brightness, connectors and response time. Here's what I mean:
FROM NEWEGG:
SAMSUNG 710N-Black 17" LCD Monitor -RETAIL
Model# 710N-Black
Item # N82E16824001158
Specifications:
Panel Type: a-si TFT/TN LCD
Native Resolution: 1280 x 1024
Pixel Pitch: 0.264 mm
Brightness: 300 cd/m2
Contrast Ratio: 600:1
Response Time: 12 ms
View Angle: 160° / 140° (Horizontal / Vertical)
Input Connectors: 15pin D-Sub
Features: Narrow Bezel, MagicBright
Dimensions & Weight: 14.6" x 15.0" x 6.9" (WxHxD), 9.6 lbs
Manufacturer's Warranty / Phone No.: 3 years parts, labor and backlight / 800-726-7864
Dead Pixels Policy: Replacement or Refund for 8 or more DEAD PIXELS ONLY!
FROM SAMSUNG:
Type
a-si TFT/TN
Size
17"
Pixel Pitch (mm)
0.264
Brightness
290cd/m3
Contrast Ratio
500:1
Viewing Angle (H/V)
160 °/ 140°
Response Time (ms)
15
Interface
Analog
Horizontal Rate
30-81 KHz
Vertical Rate
56-75 Hz
Maximum Pixel Rate
135 MHz
Resolution Maximum
1280 x 1024
Color Maximum
16.2Mil Colors
Input Video Signal
Analog RGB
Video Level
Analog: 0.7Vp-p
Sync Type
Separate H&V, Composite H&V, SOG
Input Connectors
15pin D-sub, DVI-D
What is going on here? The same information found on newegg's site is found on every other retailer's site (at least on the first google page). In any case, how does this monitor compare to the 172x? The 710n seems to have better specs, but does anyone have any personal experience or reviews they can point me to?
I just looked up the 170n on samsung website and its doesnt match neweggs or what you found. Heres what I found:
170n
Viewable Area : 17"
Pixel Pitch : 0.264mm
Brightness : 250cd/m2
Contrast Ratio : 450 : 1
Response Time : 25 ms
Interface : Analog
Max. Resolution : 1280 x 1024@75Hz
172x
Viewable Image Size: 17"
Brightness (Typical): 270 cd/m2
Contrast Ratio: 500:1
Viewing Angle (H/V): 160/140 (degrees)
Interface: Analog/Digital
Horiz. Frequency: 30-80 (kHz)
Max/Native Resolution: 1280x1024
Response Time: 12ms
710n, and i already posted samsung's specs, anyone have some information from personal experience or trustworthy reviews of the 710n (which i have confirmed is 12ms).
Yea, I also found that monitor and was wondering also about the 710VT since it seems almost the same, however I cannot find any info on it anywhere on the samsung website. Anyone tried this monitor or heard of it?
