Samsung 49" CHG9 on nVidia experiences (C49HG90DMN)
Discussion in 'Displays' started by cold_steel, Dec 2, 2019.
  1. cold_steel
    cold_steel Limp Gawd
    470
    Jun 27, 2004
    Hey guys,
    Looking at the Samsung 49" C49HG90DMN and I've seen a lot of older threads elsewhere complaining about backlight flickering issues when pairing it with an nVidia graphics card. I know this is a FreeSync screen. Do any of you have this screen on nVidia, and if so, how has it been?
  2. cold_steel
    470
    Jun 27, 2004
    Well I went ahead and got one, and actually so far so good! I'm driving it with a RTX 2070 laptop at the moment even. getting around 85 fps in CoD: MW, and over 100 in Forza Horizon 4 :)
  3. Armenius
    Armenius I Drive Myself to the [H]ospital
    19,460
    Jan 28, 2014
    This monitor flickers regardless of video card used because it uses PWM dimming to control brightness. The PWM frequency of the backlight on this monitor is 433 Hz, so it's relatively high meaning it shouldn't bother most people.
  4. cold_steel
    470
    Jun 27, 2004
    If so, I must not be sensitive to it. Looks rock solid to me.
  5. bananadude
    bananadude Limp Gawd
    296
    Dec 29, 2006
    I had flickering in many games with proper range Freesync Ultimate Engine turned on (in the monitor menu). I'd double check you are OK in this regard, as this is one of the biggest issues with this monitor. Some people seem to be OK, but its definitely an issue for many.
    Obviously make sure G-Sync is turned on within NVCP also, and the box marked 'Enable Specific Settings for the selected display model' is ticked under 'Set up G-Sync' section.
  6. cold_steel
    470
    Jun 27, 2004
    yep ultimate engine enabled.
  7. bananadude
    296
    Dec 29, 2006
    As long as all enabled in NVCP then, sounds like you're all good.
  8. cold_steel
    470
    Jun 27, 2004
    Yep knocking on wood I won the panel lottery haha
    Killahurtz likes this.
  9. Killahurtz
    Killahurtz Gawd
    639
    Sep 4, 2004
    no issues with the CRG9...2080ti...have 2 CHG9 in the house as well...the resolution is a step up
    cold_steel likes this.
