Samsung 305T owners (regular or Plus) need help
btdvox
Hi guys,
Just bought a Samsung 305T, so far the PQ has been really nice, I really dislike S-IPS SSE and SDE effects (silk screen effect/screen door effect) These are common in Rear Projection tv's and drive me mad.
Anyways I decided to go with the 305t.
After hooking everything up- the Display is a bit crooked which annoys me, it also has one small dead pixel.
BUT the main thing that im trying to figure out if its normal or not is It has a CONSTANT clicking or weird ticking sound from the back, when i poked my head around back it was actually quite loud.
Making my Watercooling System to be quite silent, that sound is kind of odd,
Is this normal? or should I be exchanging it ? reason I ask is because NCIX is quite well, anal about there exchanges and you pretty much have to fight to do so. But I dont want
to spend 1300 bucks something not perfect.
Thanks.
How far are your eyes from the screen? I hear that the SDE can be eliminated by sitting with eyes at least 2 feet away from the screen.
305T is S-PVA. Where is the dead pixel located? Is it on the center? Is it visible right away?
As for the sound, it's natural for you to hear the sound since it's got a built in PS.
If it's that loud, then you might want to fight your way to exchange it.
Im really just worried about the PS, but yes Im very sensitive to the "sparkling effect" rather known as silk screen effect on rear projection TV's, it's something I just cant get over.
Anyways I have no problems with the IQ with this screen, its more over the sound, even if it has a PS, it shouldnt be clicking away all the time....
It aint that loud but its noticeable, and i wouldnt think a LCD would havea noticeable sound all the time....
My dell 2707wfp has noticeable sound even after exchanging it twice.
I had since moved my monitor a little further and try not to pay attention to the sound.
I think the only 30'' that doesn't have a built in PS is the Gateway XHD3000
Try fidding with the brightness controls on the monitor. My 305T makes a buzzing noise if I turn down the brightness too much.
