First off, I acknowledge that this display has been addressed in other threads, but my questions are somewhat different about it.
I have a Benq FP241W, and want to also get a 30" display.
I am not crazy about the Dells, or any Dell product, the HP 30" looks OK, and the ACD was once considered great, but is quite old now, and the controls are not fully functional when used on a PC.
I am considering the Samsung 305T, which is just over $1,200 which is a good price for a 30". It has only a DVI input and 4 port USB hub, nothing else, which is simplistic, but would be fine for my use. Correct me if I am wrong, but HDCP support for a monitor is now a "non-issue" when using a HDCP-compliant video card such as the ATI HD 3850/70 that I now have, since HDCP is passed through the DVI ports.
Anyhow, almost every review of the 305T I have read is very good, and the colors seem to be very accurate out of the box.
I have no plans to hook anything up HDMI or component, so that is a non-issue.
Is there any reason not to consider this monitor other than what might be released a month after buying it?
I am not much into gaming, so slight input lag would also be pretty much a non-issue.
Andrew
Andrew
