Samsung 275T Cracking Noise
andrew168
Hi,
I have some questions on Samsung 275T, I hope someone who owns the same display can help me out.
I own a Dell 2707 and Samsung 245B, so I am familiar with the quality of these 2 displays. 245B is very well built and the entire casing is very solid, as compared to Dell 2707. When I apply pressure with my hands on 245B, it feel solid, firm and seldom create any cracking noise.
I just purchased a Samsung 275T yesterday. Although the LCD screen quality is very good (better than both Dell 2707 and Samsung 245B), I can't help it but noticed the plastic casing is not as solid as 245B. Whenever I apply some pressure with my hands on the casing or around the bezel, it creates a pretty load cracking noise. I am wondering if this is normal with 275T, since it is a larger display than 245B.
This cracking noise is driving me crazy. Owners of 275T, please let me know if you experienced similar cracking noise.
Thanks in advance.
Hi andrew168,
Mine is exactly the same. I also get some cracking noises spontaneously every now and then, probably as a result of the monitor heating. Kind of scary although i didn't really worry about it until i read your post :)
I also have a Samsung 245B and am currently trying to see which video source looks best on which screen. Can i ask your opinion, as you also own both models ?
I have a DVD player with HDMI output and upscaling. The 275T accepts only 1080i and displays a really awful image (blurred colors). Catastrophic for a screen of that price.
The 245B is offering a shaky image in 1080i but accepts 1080p with stunning results.
I'm puzzled by the 275T's bad video behaviour at 4 times the price of the 245B. Especially when considering that it's clearly superior when plugin a PC source :confused:
Are you experiencing the same behaviour? Would you have any advice on the best setup ? Thx
