Samsung 2693HM Owners Help
rkid001
I'm looking at getting this monitor, but I am not able to try it before I buy it as I am getting it from a distributor we use at work.
Can anyone give their experiences with is, I am a bit reserverd about purchasing it as it uses a TN Panel which I already have at work in my Dell E248WFP 24" and it is crap compared to my Dell 2408wfp.
However I am sending this back to Dell for a refund as it has got 30 stuck pixels and is the 7th Dell Monitor I have had on replacement so enough is enough for the 2408 now and want something else.
I saw the Samsung 2693HM and think it looks great in pictures but can I ask what anyone who owns it thinks of it?
Is it bad with viewing angles, some pics of your setups would be great as well.
I own the monitor but let me ask you what your going to use it for mainly? I'm A digital painter and need colour critical monitors that's why I will be switching this with a proper IPS panel sometime soon. That being said I've painted on this thing (I have a Spyder 3 calibrator so that helped a bit) and I've seen my work on an IPS panel and the colours barely shift. The angles are ok as long as you sit head on and even if moving slightly you'll notice a slight shift in gamma but don't expect to look sideways and find a perfect picture...far from.
The response times are really great I play Team Fortress 2 and a Crysis on this thing and I do watch movies on it and for that it's great. No dead pixels on mine but I guess it's your luck with that? Sorry I cant give you more technical info and tests as I'm not that tech savvy but I'm sure some one will and also there's a review of the younger brother on www.prad.de so you may want to check that one out. GoodLuck
