Hello,
Samsung has finally posted manual for 245T.
http://www.samsung.com/uk/support/productsupport/download/Model_Select2.aspx?type=Monitors&subtype=LCD&model=245T&fileType=UM&LSSI=%2Fuk%2Fmodule%2Fssi%2Fleft%2Flmenu%5Fmonitors%5Flargeformatdesktop%2Esec&RSSI=%2Fuk%2Fmodule%2Fssi%2Fright%2Frmenu%5Fmonitors%2Esec
Incredible amount of adjustment (including Gamma), lots of scaling mode (16:9, 4:3, 1:1, Full, Zoom), exactly listing of 1080i / 1080p 50Hz/60Hz support for component and HDMI !
If all those inputs will work properly, I think I'll it will be the best buy (even if colours are slightly off according to behardware).
Regards
Regards
