Well I recently purchased the Samsung 245T, and have so far been pretty happy with the product. I've found no dead/stuck pixels, there's no black light bleeding, and I've yet to notice the horrendous input lag that people have been complaining about (yes even in games). However, I do have one annoying problem - ghosting, or more precisely inverse ghosting. Anytime I run a light image (ie cursor) over a dark grey image (like the background of this site) quickly enough I get this black trail following it. I've heard that such an issue stems likely from the overdrive used in this monitor and is an inherent flaw of all S-PVA panels (like the Dell 2407-HC).
So my question is: Is it possible to turn off the overdrive via the service menu, and if so how do you access it?
And second, has Samsung said anything about a firmware update to fix this issue, or are they going to ignore it like Dell?
This monitor would be perfect if it weren't for this problem, and I would really like to try and correct it.
