Samsung 245BW Xbox 360 compatibility issues
rippaman77
I was thinking about purchasing an xbox 360 to use with my Samsung 245bw. However, I've noticed at some forums people having compatibility issues. Anyone have experience with the 245BW and Xbox 360? I would like to know before buying the console. Thanks.
The Samsung has a VGA input and a DVI input. At the very least, you would need a Xbox360 VGA cable. Unfortunately, the 245bw does not have a scaler, and is not capable of doing 1920x1080. Any other resolution you choose will be stretched to screen. This results in a vertical stretch that makes circular things oval.
If you have one of the newer Xbox's with HDMI, you could try using an HDMI to DVI cable. I believe that you will have the same stretching problem. Furthermore, with the HDMI option, you would have to buy the official xbox360 HDMI kit. The reason for it is, you cannot put in the hdmi cable and plug in your component cables for analog sound. The Xbox 360 hdmi kit comes with a special audio adapter that lets you use HDMI video and analog sound. Unfortunately it costs $50.
The 245bw is not a bad monitor. It has a good sharpness adjust and you can even enable pivot on it if you have the time. However, another monitor with some scaling options may be better for you. It is ultimately up to you.
Thanks so much. This is the exact information I was looking for.
Is this to say that the native res is not 1920 by 1080? I thought all 24"s was 1080p...
What am I missing?
I do not know if you have tested this yourself, but it is not entirely true concerning the analog sound. For my previous setup I had for video an HDMI to DVI converter to my 19" LCD and for audio I plugged the Left and Right audio into a converter (to 3.5mm), then the 3.5mm into the "line in" of the soundcard on my tower - which powered my 5.1 speakers.
You cannot plug both the component/RCA inputs and the HDMI cable in without some finagling!
The grey plastic cover on the end of the component/RCA cables that go into the x360 is not entirely necessary, and after about 5 minutes of working it with a flathead screwdriver I had it open. I removed the bottom portion of the grey cover and sealed it with electrical tape. No it is not attractive, but I did not spend $50 and I may not ever see it again as it is behind my x360.
Another alternative, If you know someone with an xbox 360 elite, is to acquire their audio dongle - it has L/R RCA output as well as optical!.
The audio dongle is to the immediate left of the HDMI cable in this pic (see bottom left)
imgres
