You can verify the panel by looking in the maint. screen...also, some of the older ones had the letter on the back (like my S-panel does).
So tell me why they look and perform so differently then? One is good for gaming the other is terrible for it. I've used both for extensive periods of time. This website: http://www.digitalversus.com/duels.php?ty=6&ma1=36&mo1=224&p1=2104&ma2=36&mo2=284&p2=2683&ph=12 proves what I felt and compares them both. 30+ ms average input lag vs 1.6ms. Colors, viewing angles, best rendering are all obviously worse on the 2232bw.
Like I said earlier...the 226bw is much better for gaming. When I had the 2232bw for 3 weeks I noticed right away - the input latency. I now have a 226bw s-panel...it's a non issue (thankfully). People who are on LCDs with 30+ms input latency such as the 2232bw claiming they don't feel any lag just didn't play at a high enough level on a CRT I guess? I don't know how else to put it. www.esreality.com if you opinions on these matters from people who take gaming a little more seriously than most.
If you've played warsow (or play it) try selecting a resolution your lcd monitor supports up to 75hz. Type /vid_displayfrequency 75. Compare 75hz vs 60hz and write back again with your findings. This isn't an issue of guessing...the pro community already knows 75hz LCDs look and feel better than standard 60hz.
where do you see that it was the cpo version? that is what they refer to as CDA right or are there 3 panels? I think mine is the CDA and I've just got done playing UT3 and still don't notice any input lag compared to my 206bw. compared to a crt, yes a little.The input lag they discovered was with the CPO panel of the 2232BW, i have the SAMSUNG version of the 2232bw panel, and let me tell you, with RTA on there is no ghosting, with it off there is ghosting, now there is a good side of rta and a bad side, good is it makes the response time noticibley faster, bad is it brings on green ghosting trail sometimes, most notable on the front page of xtreme systems forums......i turn rta off on the desktop, and turn it on while gaming.......2232BW is the most responsive LCD i have ever used.....i have used the 226BW, and this is better.
