craigrpeters
- May 29, 2007
I happened to get a "C" version of this panel, and overall like it very much. But one thing I wanted to know, has anyone else noticed a red shadow with black letters on a white background (especially using the default Windows System font)?
I have ClearType enabled, and have the DPI Setting at "Large size (120 DPI) so text doesn't appear so tiny. I'm using the color profile someone recently posted at 75% Brightness/Contrast. Using my own eye vs. the posted color profile didn't make any difference by the way. I don't notice the red shadow as much at 96 DPI, but the words are so small that doesn't mean they aren't there. I think the effect is greater when slightly off center, for example with words nearer the top or bottom of the screen if my eyes are on center.
Just curious if its a specific issue with my panel or normal thing (maybe for TN panels).
Thanks in advance,
-Craig
Thanks in advance,
-Craig
