That is precisely what I did, I first bought the 226BW and recieved an "A" panel, spent 3 days trying to like it, returned it, and waited for the Dell price drop + 10% discount; $899AUD compared to $560 for the samsung. Very nice monitor the only problem I will have to upgrade my 7900GT.... saving up some more and going with the 2407WFP.
Can you make some pictures, we can discussed then.
Yep, Samsung Panel lottery sucks a lot.
Link: [H]ard|Forum page #73 KungFu-tse have also received a C panel, discussed here.
Link: Forums.Whirlpool.net.au: Discussed about the Samsung C panel.
Link: Samsung 226BW C panel Made by Chi Mei Optoelectronics panel, Monitor Application: 22" Model Name M220Z1-L03
Hope this help
That sucks about the check deal!!The Samsung just didn't look the way I wanted it to. I returned it to BB and went to CC to buy the LG L226WT which I like better. Btw I payed cash for the Samsung at BB and now I have to wait 3-5 days to get my money back in check form.
I've seen this photo on another forum that makes me think the 226bw has 1:1 pixel mapping after all...
http://img378.imageshack.us/img378/2031/img0389ht1.jpg
It's running at the native laptop resolution which is 1280x800. Does it only do this because it's connected dual screen?
Then why would there be a demand for 1:1 pixel mapping on a monitor if most of the time this can just be accomplished softwarematically? Also, you suggest that it wouldn't work on a console for instance then?AFAIK all nVidia drivers and ATi _mobility_ drivers are able to force this (don't know about Intel drivers and the rest of the bunch). Also I noticed that even with a normal Radeon (desktop) some resolutions are displayed this way (windowboxed from all sides) on the 226BW while others are stretched to fill the whole screen. All in all, this picture proves nothing I'm afraid..
No, Samsung policy is to hidden that for his customers, the only place is the sticker behind the cover, but check for confirmation inside the OSD ' Service Function ' the panel type.
We have seen at last one Samsung 226BW here that's give on the sticker a other panel letter then in the ' Service Function ' showed.
I went to Circuit City yesterday I did see the 226bw on display and it was the S panel so I had the guy (from CC) check the other box in the back to see if it also had a S in the serial number he stated no but did not tell me what it had. My question is there even a way to tell without opening the box?
With PowerStrip you can make easy 3 new full screen 16x10 resolutions, this are mine, quality is close to native 1680x1050 - added with 16x10 aspect ratio and full screen 1152x720 - 1280x800 - 1440x900,
design a resolution in a resolution etc. (not all videocards support all features, but is a nice tool)
Link: PowerStrip
On my A panel, when playing back a DVD movie you could see where the black bars cut off and where the panel was trying to show black. On my Hanns-G it was pure black, on my A panel it was dark grey. My Hanns-G had absolutely no backlight bleed. I expected some in my A panel because it's a problem with 22" TN panels, but not to the huge extent that I had it.
Hey guys, I got my Samsung 226BW 22" few days ago (A panel ). The pictures and video look perfect but the text is slightly blurry. Some of the letters give the impression that has reddish or greenish borders. Also, the text in the taskbar is more blurry compared to text in the middle. In general, they are very readable, but distracting, as it is not of the same visual quality as the rest. This is the first widescreen I have ever had, and didn't want to assume that it was a fault straight away. After checking drivers and playing with settings however nothing helps the problem go away. Is this normal????
Are you hooked up through DVI or VGA connection and what model video card?
I'm using DVI connection and NVIDIA GeForce 7600 GT. (Also running Windows Vista Business)
