Stu, it's NOT a Samsung, but an LG and the name is LG L226WA. I found the answer below on an other thread and it's as follows:
"You can check out the Canadian chain store, (also owned by Best Buy), site at http://www.futureshop.ca for the differences between the L226WA and the L226WT.
Basically it looks like four inputs for the L226WA model: VGA, Component, DVI-D and HDMI. Supposedly the WA is the 2ms model, and the WT is the 5ms model, and the WA is manufactured in Korea, and the WT is manufactured in China. Do not know if that means different panels or not. Those are the differences listed on the labels on all the boxes that I saw in-store. Looks like there are black and silver versions for both. The DVI-D cable also comes included with the WA model."
In spite of this, I found info about the monitor only on German and Chinese sites when you plug LG L226WA into Google. I think I also saw some scant description on LG's of Philips' site (one of the two). Sorry for the mistake that it was a Samsung.
As previously mentioned in this thread, there is also the same little bit of top and bottom backlight bleed on the WA model as well, but you cannot notice it unless the screen is black.
