Jun 14, 2007 #1 C Cyberops n00b Joined Jul 10, 2004 Messages 19 hi, i've a doubt. Does any of you who own a 215tw, has the letter which is on the sticker behind the screen, different from "S"? can i've the bad luck to buy the 215tw that have the "A" in that sticker? thanks and sorry for the poor english
Jun 14, 2007 #2 T ToastyX [H]ard|Gawd Joined Mar 12, 2005 Messages 1,402 The 215TW only uses Samsung S-PVA panels, but I wouldn't recommend it because it has 50-60 ms of lag.
Jun 15, 2007 #3 S senakun Limp Gawd 2FA Joined May 18, 2006 Messages 330 The 215TW looks great, but.. on all 3 that i used. the backlight was brighter on the left side. so in dark scenes, u see it quite clearly. i had to sit off center to cut down the effect, just to the left of the Samsung logo.
Jun 15, 2007 #4 C Cyberops n00b Joined Jul 10, 2004 Messages 19 thanks for your answers. btw is there any leak of info that refers to an update of this model or panel?
