According to the specifications, the 205BW has a 15-pin D-sub and a DVI-D for video input. My question is, can I connect a Wii to this monitor? Or is there some cable I can get to connect it?
this may or may not help you, i used to have it, it has a standard DVI connection, that would go to the back of a video card, and a standard VGA connection...the only way this would help you, is if you have a WII and it has one of those 2 connections on the back..if not you will need some sort of adapter
