samsung 193p review
abarsami
Here is my quick summary.
19" / 20ms samsung 193p
I just got this lcd. So far I miss having buttons on the lcd. I tried the MagicTune software. But in the end I'm sticking with good old ATI to adjust my settings.
The pivot part of the stand is not sturdy enough. If you lower the lcd a little and shake the table a little the lcd lowers automatically.
For gaming this is better than a typical 25ms and worse than the 2001fp. I've seen my friends 2001fp and ghosting is better on that. I tried Unreal 2k4 and did notice more ghosting on inside levels than outside levels. After playing for 5 minutes I didn't notice it much.
Colors - this is where this lcd shines. It has the best colors I've seen yet on an lcd. The design is also top notch.
That's it. I'm not sure if I'll keep it based on the crappy pivot stand not being sturdy. Might wait it out for a 19" s-ips 16ms panel.
I got it at Fry's. I will play with it for a week. Probably end up keeping it.
NEC is suppose to release a 19" s-ips panel in fall of this year - ie will probably be early 2005 before you can actually buy one :) .
try getting a replacement, i have a 173p and the pivot is very solid. I shook the desk and it didn't budge. of course, maybe the extra weight on the 19" causes that.
do you do graphic work at all? How bout dark colors? on my 173p, the darks get lost. You can check that out by looking at the greyscale here. Do the dark shades of gray look black? Are all shades evenly spaced?
I think it is just that the 19" is too heavy for the base. I returned it. The colors were really good though.
