I got the 193P+ a few days ago and it's a fantastic monitor. Amazing contrast, colors, sharpness, viewing angles etc. However, there is one thing I'm concerned about. Only two days after I got the monitor, the newer model, the 970P became available here. It has the same specs but supposedly has a faster response time (6ms vs. 8ms on the 193P+).
Now, the 193P+ handles games pretty well. In games with lighter colors I see no difference compared to a CRT. However, certain color transitions still ghost a bit. Mostly noticeable on black vs. *certain* shades of grey. For example, in Operation Flashpoint (game with mostly grey colors) I noticed a black tree that ghosted a bit againts the grey sky when I turned left and right quickly. Only a couple of minutes later, I tried the same at the exact same position and there was no ghosting at all. As soon as the color of the sky had changed only slightly, the ghosting disappeared totally.
My question is, is there a big difference in speed between the 193P+ and 970P? According to guys at Behardware there is, but from what I've seen, they have never even tested the 193P+, only some Fujitsu Siemens monitor that uses the same panel. I think that shouldn't matter much since there are many monitors that use that panel and they are obviously not all the same speed. So, do you guys think I should exchange my monitor for the 970P? I like the looks of the 193P+ MUCH better and only if the 970P was noticeably faster would I consider doing that. If there isn't much difference, I'd rather stay with the 193P+ as it's pretty much perfect (no dead pixels, no backlight leakage at all, better looks etc.). I know this is a long shot but has anyone by any chance had the opportunity to play games on both monitors and could tell whether there is a big difference between the two?
