Samsung 172x personal review
Grolandi
OK, just got the Samsung 172x from MonitorsDirect today so this is a very initial review...
This is the 4th LCD monitor I have tried. The others are a Samsung 191T, Proview (AU screen), and last was a Sony HX73.
172x is a very nice looking monitor (as you can see in the many photos on other web sites), solid feel too. Smallest shipment box I have seen. I have two dead pixels in this screen. Love the narrow bezels. I've using both the DVI and Analog. Seems the Analog has issues with lines and other weird things...see EDIT further down...
Controls are terrible, the worst ever. 5 buttons with labels so small you can't read them. You have to guess and learn. They also are hard to press and you end up pushing the screen around, but you don't end up moving its hinge setting. The screen just bounces a bit. The monitor does not rotate in any direction except tilting forward and back.
Nice long power cable, but other cables are about as short as you find with most monitors.
Games Played: UT2003, UT2004 Demo, Far Cry Demo, C&C Generals
This monitor is *not* a 25ms. Whether it is a 12ms or a 16ms, I'm not sure. However, it does not seem to ghost much, if at all. To me is does seem to have a very slight ghost but one that is not a problem to deal with (and I hate ghosting). I run a test in UT2003 which shows ghosting everytime (certain map, certain area). It seemed to ghost a tad but not sure if it was more or less than the AU screens. Still, very very good.
The thing I really like about this screen over the Sony HX73 and the AU screens is how it dithers (or doesn't). Those screens do a weird cross-hatched pattern dither, this Samsung 172x does not seem to do this. I even notice a "windowsblind" effect after playing games with a AU screen, but haven't seen anything like this with the 172x. You get a nice clean image.
Colors: This has been hard to determine. I've seen them looking just awesome in UT2003, but usually they seem washed out. There is also something very strange about how this screen handles brightness. I think the MagicBright is screwing things up a bit. So far though I have found that I can turn down the brightness in the games to make things look right. It's hard to explain this.
**EDIT: This problem turned out not monitor related....>>BIG PROBLEM: There is a serious problem when you turn down the brightness below the level of the contrast in UT and it seems like something similar in C&C Generals. When you do this the colors go psychedelic!! I mean really really strange. You can't look at it for long. I have no idea what is going on. Might even be a bad monitor but I bet this might be an issue in all of them. Would love some feedback from other users on this as people get this monitor.
THE GOOD:
Nice looking monitor, narrow bezels.
Excellent response times it seems
Great colors when brightness is set just right
Very small footprint (I had to check to make sure it really was a 17inch monitor)
Doesn't do the stupid dithering like the AU screens.
Doesn't seem to blast (bright) the screen into your face like the Sony HX73 does.
THE BAD:
Terrible controls
Weird problem with brightness and contrast (needs to be fixed)
Expensive (but the good ones are now)
EDIT: Resolved the analog problems (interference problem...can't believe the number of issues I had right after installing this LCD, not its fault). Looks great! Can hardly notice a difference between DVI and Analog...maybe a tad soft, but one of the best looking Analog LCDs I've seen.
Anyway, I need to track down the problem with the brightness...maybe drivers (I haven't install the CD yet).
I don't get this problem with the brightness, but it seems to have stopped after messing with the color balance a lot. Not sure why that fixed it but all seems better.
I had to use the Samsung "Natural Color" program instead of the Nvidia one for getting the color just right.
The response time still seems good mostly but at times looks quite fuzzy. I've been playing UT2004 much of the night with no ill effects. However, when testing in Solitare (moving a card around) you can see definite ghosting. Far cry has been good, but I can see some blurriness due to ghosting. Still, very playable. In some ways it seems better than my Sony CRT. Wish I had the Sony HX73 to compare side by side.
Getting a handle on the controls too. Not so bad after you use them a bit, but still not the best.
The double hinge is interesting, but not easy to use. It's hard to adjust to just the right level. It's a two hand process...one adjusting the other holding the monitor stand so it won't move.
Wish this thing came in black instead of silver. These thin bezels are just calling for it...they would almost vanish.
Starting to wonder if this is more of a 20ms screen.
bump. Thanks man. I've got one of these coming soon too!
Does is come with a DVI cable?
Yes.
You can also hook up both the analog cable (included) and the DVI cable (included) at the same time. The monitor can automatically detect them and switches automatically as well. You can however force it to use one or the other. I haven't tried it, but I assume you can have two computers hooked up to it.
Again, I have noticed some problems when using Analog. I don't think it is computer related since I have used Analog for CRT, but also for LCD. It might just be a specific monitor issue.
Well I won't care about the analog problem. DVI all the way.
Also, could you expand on your brightness and contrast problems? You fixed them, did you not?
thats worrying about the possibility of a 20ms panel. Samsung is just way too shady about their response times, especially with this monitor.
After messing around with Samsung's Natural Colors program, to get the colors I want, it seems to have greatly cut down the problems. I can still get them to happen to a lesser degree by going into the Nvidia control panel and changing the brightness and contrast of the blue color.
The problem was that in a game like UT2003 I would set the contrast (ingame) to less than the brightness (ingame). Any degree setting of contrast less than the brightness and the screen would go crazy. I mean SERIOUS color issues. Blues would become yellow and flash for example. Other colors would change and do other weird things. It would get worse as I made the greatness of difference between contrast and brightness.
But, I haven't seen them for several hours now and all seems pretty good in this regard. I can now make the contrast less than the brightness ingame on all the games I have tried.
Add Silent Storm demo to the list of games too. Going to give Simcity 4 and NeverWinter a try today.
I have a hard time believing this is a 12ms monitor. Now that I'm getting used to the monitor, I can definitely see ghosting.
Dang, I wish I had a 16ms screen to make a side-by-side comparison. I had to return the Sony HX73 two days before I got this one.
Compared to my TV (cloned), there is some definite ghosting going on, but I haven't found it to be a problem really.
I did find the Samsung 191T (25ms) to be very difficult to use. My eyes kept wishing to focus when things were moving, and blurring, due to the ghosting. I don't seem to have this problem with the 172x.
But, the 172x doesn't seem to be as ghost free as the Sony HX73, but but but...I do like the non-dithering feel the 172x has over the Sony. It's just feels more like you are looking through a window instead of seeing a computer screen.
Right now I'm really torn as to whether I like this monitor or not.
Love the small footprint. Nice looking too.
Colors are getting better after messing around for an hour or two but I have never had to mess with the colors on the other 3 monitors to make them look even this good. The Samsung 191T was be far the best for colors (droooool). The colors on the 172x seem a bit washed out still. The Sony HX73 was quite nice in this regard except when it was dithering...not the best, but very good.
View angle seems better than the Sony HX73, though they spec the same. I believe they are the same, but the 172x looks better for some reason.
Brightness is better on the Sony HX73, but it was always blinding no matter how much you adjusted (without lossing too much color depth). The 172x gets quite bright but not as much, however I do like how dark it gets...easier to read text on. I've read LCDs get darker after 5 years, so maybe this could be a problem for the 172x in the future.
Ghosting (172x) vs Dithering (Sony HX73)...I'm really struggling over this one. The 172x is not 25ms. But, it does seem to ghost a bit more than the Sony HX73. However, I'm not sure if I hate the ghosting or the dithering more.
Tough choice. The 172x doesn't seem to be the end all choice, but it might be the best one for me.
Monitorsdirect screwed up my order and shipped it Saver when I paid for Two Day so it will be one more day before I can give some complimenting feedback. :(
You mentioned you have an NVidia vid card. I have a 9500 Pro. What are the rest of your system specs?
Thanks for posting your impressions. Sorry if you mentioed it already, but how are videos?
It seems like most of your problems are coming from gaming. If you're a heavy gamer, none of the monitors you had are right for yout. Get a CRT. If you do light gaming, though, then response times and dithering are important. Also, I'm sure it's a 12ms panel. Samsung said they wouldn't release this monitor until they perfected the 12ms panels. There is NO WAY it is 16ms, or any higher than that, for that matter. YES, I am aware that the test models had 25ms panels on them, but they weren't released onto the market until the 12ms's were perfected. I'd be willing to bet you have a 12ms model. ms doesn't mean everything either. There are tons of other factors that contribute to ghosting, dithering, etc. The response time rating certainly helps reduce ghosting, but it's not all in the ms rating.
If it was really 12ms he wouldn't see any ghosting at all. Hell, even a true 20ms response time should have no ghosting. The reality is that the way they measure these response times differs from real world applications where you change from one color or shade to another.
Thanks for makin the comparison to the sony monitor. It helps to hear what people who have owned both feel.
Nvidia Ti4200
As for videos...hmm, something isn't quite right. It looks great when the video is windowed, but there are lines of shifted pixels that "flash" on the screen when the video is fullscreened. I honestly never tried videos on the other LCDs since my TV is right next to the computer.
I must say otherwise the videos look really nice, better than the TV. I will need to hear if others have a similar problem with the lines. Might just be the video card are something.
More info on the weird color problems...
It's *not* Samsung related. I got something similar to happen on my TV (cloned). It's something funky with the color correction/adjustments in windows. Good to know.
I've stopped using the MagicBright software btw. Only using the color profile created with Natural Color.
I can't use a CRT any longer due to a disability. This is why I'm looking for a good LCD.
I'm really not sure about the 12ms claim. It definitely ghosts a bit in places and that really shouldn't be happening at 12ms (that is only 3/4 the time of 16ms, at which you don't see much ghosting already).
It might be a 12ms, but things don't seem to show that claim as many would expect it to.
I agree, but do know even on the 16ms you do get some ghosting.
Dang, really wish I could compare side-by-side.
Wow, Newegg sold out of the 172x fast, and so did MonitorsDirect. Newegg boosted their price by $20 too it seems.
Wow...Fedex delivery date changed and it's there waiting for me to get home from work. I should have it hooked up in about four hours.
Had to finish assembling my rig before I could hook this up last night and by the time I was done patching, It was 4 hours until I had to get up for work.
I just futzed a little with the brightness and contrast, but, regardless, eyestrain felt worse for me on this LCD than on my CRT. Maybe my eyes just aren't used to it. Graphics look clean and smooth, but when you have an edge between light and dark colors, the edge seems a little rough. Text is also blockier, but I know I need a utility to make the text look good.
The stand is way too short. Adjusting it to maximum height only takes it like 4 inches off the top of my desk which means to be able to look straight at it I have to tilt it backwards.
I have one amazingly annoying bright green stuck pixel in the middle of the screen and at least one dead pixel on the top right. They're way bigger than I thought they'd be. The bottom right corner of the screen is much brighter than the rest of the screen which may be what was bugging my eyes so much.
UT2004 Demo loaded up fine. I set the resolution to the monitor's native res and played single-player deathmatch against some bots for about a minute and could not discern any ghosting whatsoever. Again, as someone coming from CRT, maybe my eyes just aren't used to looking for it, but I couldn't see any even when jumping and firing rockets like a madman. After a minute it crashed and I couldn't get into any UT2004 games. *sigh*
Tonight, I'll load BF1942 which I play a LOT and will let you know anything that looks different...good or bad.
I'm using the DVI connection with a 9500 pro, 1GB PC3200 Mushkin, 2500+ at 3200+.
The lines in the video seem to be a driver issue.
I ran the videos in Analog mode and didn't see them at all in fullscreen. I also ran the video in Analog and Digital (clone mode), watching the Digital output, and it was fine even at fullscreen.
So, there is a driver issue I guess, or some hardware issue with the graphics card. I don't think the 172x is the problem.
Movies look great, much better than the TV, but I haven't seen many movies on other LCDs to compare.
There is a view angle "problem" (160/140) if you wish to have multiple people viewing the movie, but for one person they are just fine.
Dang, if this one pixel wasn't a problem, I would be starting to enjoy this monitor more.
If you are running XP, turn on the ClearType.
I could see this being a problem now that you mention it. Being disabled means I'm not at a desk.
Yep, these bright pixels are a pain. I have a dark one and could care less about it.
You know, I was wondering about the bright bottom right last night too. Wasn't sure if it was just my position or a true bright area. Not really a problem for me. Hard to find LCDs that are perfectly uniform.
Try Solitare, if using Windows. Just drag a card around the screen, not too fast but enough to ghost.
Love to hear it.
I tried solitaire last night since I read your earlier posts and tried moving some cards around and still didn't see any ghosting.
I DID see significant ghosting whenever I was loading something. That progress screen with the black file names zipping by on the windows-gray background had major ghosting of the file names. That was the only ghosting I noticed.
Again, I'll test more tonight and have tomorrow off to do more extensive testing.
I'm using Win2K.
you say it ghosts some but its not a 25ms panel. you say the 172x Is slower then an 16ms AUO panel but does not dither. and the 20ms Hydis panel is faster then the AUO panel and does not dither. As i can tell from your discreption that your panel is about 22-25ms and dither free. Since the Hydis panel ghosting is barley visible and you say your 172x ghosts more then a 16ms AUO panel and the 20ms hydis panel ghosts less the the AOU panel. so again, i think your 172x is a rated at 25ms. Send it back
It could be related to many other factors. It still could be a 12ms rated screen but handle certain color responses slower than others. 12ms/16ms/20ms isn't the end-all way to know if the screen is good for non-ghosting. Just as you stated, the 20ms Hydis screen is better than the 16ms AU. So maybe the Samsung 12ms is not as good as the 20ms Hydis either.
I'm not saying it isn't yet...and I haven't seen a Hydis 20ms, but the screen could indeed be a 12ms, but feel like something else.
Okay...I retried solitaire and could see the ghosting. I got my computer fixed and played UT2004 Demo for a few hours today and couldn't, no matter how hard I looked, see any ghosting. I had it set at 16 bit color and set it to the monitor's native res.
I'll get some more things installed and test them out.
This one is going back next week because of the green pixel. Not sure what I'll do.
At first, my eyes strained more when using the LCD, but now it feels a little better than the CRT, so I'll probably try the VP171B or the Sony, whichever they have in stock, and make a determination after that.
The difference between the VP171b and VP171s is that the latter has a silver-coloured bezel instead of a black. The VP171s also qualifies for the TCO'03 standard, compared to TCO'99 for the VP171b (thanks to the silver bezel?).
AU screens are out for me I think. This 172x is better.
But now I have read some more 173P reviews. This screen is great in every way but I'm not sure about the gaming. It is a 25ms but the reviews say it is good for gaming.
Too many choices...
Im currently looking for the Samsung 172X like a madman, its pretty damn hard to get hands on here yet(in Denmark)
I have seen alot of post and reviews of this lcd monitor and it seems very nice all though this "personal review" got me a bit worry´d.
- Grolandi are u still using the 172X ? and is it better in games than the AUO panel lcd´s in games ?
Oh by the way im new here and this is my first post :)
I've decided the 172x is a better monitor for my needs than the AUO screens. I consider myself a heavy gamer (play several hours a day, all types of games), which is why finding the right LCD has been difficult. The 172x is a damn fine screen.
The 172x is not the be all end all, but its uniformity of color makes it the better choice over the AUO screens for me.
I might try the 173P but there hasn't been any serious gamer reviews about that LCD yet. Only one review here mentioned ghosting in movies and that doesn't seem like a good sign, though they saw no ghosting in UT2004.
If I got stuck with a 172x, I definitely wouldn't complain. I'm used to the controls now, learned most of the serious looking issues were not monitor related, and haven't found the apparent tad of ghosting to be an issue (I'm really picky).
The only one thing left seriously bugging me is this one bright pixel. Otherwise, it's just my desire not to be missing out on something possibly better. This has been the best gaming screen I have used out of the past 4 LCDs. I'd take the 191T for a work office screen any day otherwise (that is a great screen, but not for gaming, terrible).
Hi!
I've got a 10 year old 17" Yakumo CRT (laugh all you want) and I THINK I'm in a need of better treatment for my eyes. I've read some of the stuff here and come up with two choices: 172X or VP171b..? I know both monitors are getting great reviews and all that but It's hard to say witch one... Both are so damn good so I can't go wrong either way I guess.
BTW thank for your posts! It's been a great help for me on my quest finding the best damn LCD ;)
Hi!
I got my 172x today :D
For me the design was an issue and i really like the narrow & slim design and the fact that there is no product name on the frame of the display (just on the foot).
I've only had a 19" CRT before this TFT, so i'm afraid i really can't compare it to other TFT's. I have 0 bad pixels and the sharpness and colors are fantastic in my opinion. I was just a bit worried that maybe i would get an older 172x model with the 16ms panel, instead of the new 12ms. Either way, there is no way to tell which one is inside, so i'll just hope its the faster one. Manufacturing date at the back of the TFT is January 2004, made in Malaysia.
I haven't seen any ghosting effects playing counterstrike or return to castle wolfenstein. There is motion blurring when you strafe from left to right along a wall. I guess this is normal for TFT's?
@Grolandi: Maybe we can compare some settings & facts?
Whats your manufacturing date?
I set my contrast to 22 and my brightness to 90.
I'm running it at 1280x1024 @32bit @ 75Hz
For the moment i'm still using analog until i get my DVI cable.
Let's see what else did i notice ....
-the buttons on the tft you get used to pretty quickly, i'm glad they are small and hardly noticeable.
-The dual hinge system is nice to fold up for a lan party, but if you plan on changing the angle daily, it might be annoying.
-when you scroll text, the text flickers a little
well maybe more things later, wait for responses first ;)
ADDED: BTW. there was no DVI cable included and samsung also doesnt list dvi cable as an accessory... :confused:
