Sammy 204b dud...help
Uplinkpr0
I recently got a beautiful samsung 204b r -_- best lcd Ive laid eyes on but then I had the flickering problems. Well after nearly kicking a geeksquads @$%!@ !@# I finaly got it returned. Now heres my Thing, I still need a new monitor. And I want one that looks just as good if not better. Im not fond of WS but after looking at a few 22in for 400$ and under im in a rut. Im looking at the Acer AL2216WBD, The Samsung 225BW, The Veiwsonic VX2235WM, and the Gateway FPD2275W. Im in a rut I want the same if not Better Quality over DVI cuase thats all the 8800gtx supports I would go the route of the 24in gateway but thats a little out of my budget. Please give me your input what should I get !! :confused: :confused: :confused: :confused:
I'd recommend the FPD2275W ... it has the most bang for the buck ... VGA, DVI (w/HDCP), Component, SVideo, Composite, 4 Port USB 2.0 Hub, auto-rotation option (need to add optional stand). Plus it has some very cool auto-hiding PIP functionality as well. It should be readily available at www.gateway.com or at Best Buy ....
As I and a couple others posted here, there does seem to be a bleed issue on the Gateway FPD2275W. I haven't yet decided whether it's too irritating to keep the screen, because it's otherwise rather pleasing.
