Sgraffite
- Jan 10, 2006
I was having trouble getting the virtual machine to work on my workstation, so I copied the virtual machine from my server. I waited until the server finished a WU and sent it in, then I stopped the vm and copied the files over. Then I started them both at the same time and they both picked up Project 2605 (Run 6, Clone 113, Gen 19). Is this bad that it is exactly the same, or am I being paranoid?
