Polarhound
I suck at [H]F
- Feb 11, 2003
Last week my old HP died. Replaced it with an Asus box from Worst Buy since it had a PCI slot and could keep my old ZyXEL network card. While network card and router (DI-524) are the same as before, with antennas and computer in identical positions, latency has gone through the roof.
For years I had the router set to channel 11. Pings in WoW averaged around 80-110ms playing on a server two time zones away. First night with new router, had to change to 6 to get decent ping. Second night, channel 1. At the moment I'm on channel 3 and still iffy connection.
Distance between router and NIC external antenna is only about 5-6 feet, with nothing but a wooden wall, wooden floor and some carpet in between them.
I've tried the external antenna in multiple locations to no avail. It's hard to believe that interference from the new computer could be that much of an issue given the close distances between antennas. I have ruled out RFI from an el-cheapo PS in the Asus box by replacing it with a 650w Antec as well.
Any ideas?
Edit: Trying one more new thing now: Antenna is now hanging off the top of my secondary monitor (Viewsonic 1912) which sits on top of the tower. The antenna is now about a foot closer to the router. Running a fresh batch of ping tests to google.com right now. Last time around I got 20-22ms rounds for a while, only to have it shoot up to 400+ after a bit, so will have to do a bunch to see.
Any ideas?
