- Feb 16, 2003
My Logitech Cordless Duo keyboard died on me after 2 years. Well... the up arrow key died but that keyboard is used for games so it's crucial for me to have that. Anyways, I went and bought the Saitek Gamers Keyboard which boasted the "cool blue" backlit keys, a launch command pad with 27 programmable keys for game commands. The board isn't the most stellar looking thing, with it's odd corners. But seemed to have some pretty nice features as well as a USB connection.
So I attempted to set up the command launch pad to run some game macro's/commands.
You know, the GTA3 - gunsgunsguns cheat would be for button 1 so that I could just hit the button once and it would send the command into the game and I wouldn't need to type it all. Anyways, it didn't work. So I updated the programmable software from their website (Which has an odd long install process), and attempted it again. Same results.
So I tried a few other ways and ended up with the same results.
Finally I decided to e-mail Saiteks support team to see if there was something I was missing, either some sort of hardware conflict or if I had just missed a step. My response came a few days later. Here's what I got. Now, mind you the product does not come with a manual or anything. So I had to go to their site to read through the steps.
"Hi,
Have you used the programmable software yet?
Dont think so.
Best Regards
James Laird
Tech Support
Saitek UK"
Now, I usually don't contact the support teams for products because most of the time, I've either figured it out by the time they respond back, or the response I get is not as useful as I would have hoped.
Was it too much to expect a normal, decent response from a tech support of the company I just purchased a product from? Automatically assuming I had not used their software, and the final kicker comment of "Don't think so."???
"Hi,
Dont think so.
Best Regards
James Laird
Tech Support
Saitek UK"
