Saitek Cyborg Keyboard Problem
tveezz
I have the Saitek Cyborg Keyboard and I'm using it with Vista Home Premium 32 bit. I used the keyboard without problems from 4/08 to 10/08. Now the keyboard is completely unresponsive on my Vista machine. When I connect it to my Windows XP machine it works perfectly. I have removed and downloaded the latest drivers from Saitek half a dozen times and no luck. Does anybody have this keyboard and were able to solve this issue? The Saitek forums and Tech Support have been no help.
Thanks for any help!
Dave
Well, if it used to work, but doesn't now, and still works on a different machine; sounds like windows itself is hosed. Or you may even have a buggy keylogger or something installed (malware). I'd run a couple of scans to see if you may have malicious software installed. If you don't, a re-install of windows might be in order.
What he said.
Mine has been flawless since I got it last winter in Vista 64 bit.
OK, thanks for the input. Looks like a format is in my future. Until then i'm using my G15 and have no problems with it.
