Sager, ThinkPad, MSI... oh my!
steveak
I haven't checked in here in ages, but I'm researching a new laptop for my wife for Christmas, and I'd appreciate any feedback.
I'm looking for a mid-range machine, and long-term stability is a key point. The computer will probably only ever be used at home, plugged into the wall. Internet, email, online video, photo editing, Office applications.
She's not a gamer, so built-in graphics processor should be fine. She would not need the fastest CPU either.
I've configured out several builds from powernoteboks, lpc-digital, and xoticpc, and all are similar, with the differences showing up in pricing. If needed, I can reduce my costs by going down a bit in hard drive size, going with the built-in wireless, or going to single sticks of memory instead of dual.
From high to low:
Sager NP2650
15.6" (1920x1080)
Intel HD graphics 4600
i7-4710MQ
8 GB (4x2)
1TB (7200 rpm)
8x dual layer DVDRW/CDRW
AC 7260 802.11 ac/a/b/g/n, Bluetooth 4.0 (dual band)
Windows 8.1 (64 bit)
http://www.lpc-digital.com/sager-np2650.html
$964 (xoticpc has the same price on this configuration)
ThinkPad T540P
15.6" (1366x768)
i5 4200M
8 GB (4x2)
1TB (7200 rpm)
Intel Wireless-N 7260 802.11 b/g/n + Bluetooth 4.0
Windows 8.1 Pro (64 bit)
http://www.powernotebooks.com/configure.php?special=1766
$877
MSI CX61 2PC-499US
15.6" 16:9 (1366x768)
GeForce GT 820M
i5 4210M
8 GB (4x2)
1TB (7200 rpm)
http://www.xoticpc.com/msi-cx61-2pc499us-p-7242.html?wconfigure=yes
$863
PowerPro J 5:20
17.3" 16:9 (1600x900)
i5 4200M
8 GB (4x2)
1TB (7200 rpm)
http://www.powernotebooks.com/configure.php?special=1672
$863
ThinkPad Edge E540
i7 4702MQ
8 GB (4x2)
1TB (7200 rpm)
Windows 7 Pro (64 bit)
http://www.powernotebooks.com/configure.php?special=1792
$797
I know the quality we would get with the Sager. I don't really know the overall build quality of the MSI, but I'm sure they do a good job. From what I've read, the PowerPro models are built on an MSI barebones; is that right?
Then there are the Lenovos. That ThinkPad Edge comes in at the lowest price, and has an i7 processor.
The PowerPro has a 17" screen.
The MSI has a dedicated graphics card.
So, what do you think? All of these would certainly do for what my wife needs; in fact, this could be a bit of overkill. But I'd be hoping to get 5 or 7 years out of it. Yes I could just head to Best Buy and pick up something for $100 or $200 cheaper, but going through one of these builders should give a more solid build, as well as provide better service if needed.
(She's currently using a build from AVA Direct, ordered back in '07, as I recall, when AVA was very highly though of on this forum. That comp is finally showing its age. Ha! Speaking of showing its age, check out my build in the signature. It's time to build myself another one as well!)
How about the Thinkpad Yoga 14" laptop/tablet hybrid for $1099 at Best Buy with i5, Nvidia 840M, 1080p touch screen, 1TB HD with 16GB SSD cache?
I should have indicated pricing desires in initial post, but $1099 is outside of my price range. I'd like to be under $900. Also, she's rather have a larger screen than 14". I'd like to go with 17", actually, but those end up pricing most things out of my range, so that's why most of my configurations are 15" screens.
I'd recommend staying away from 1366 x 768 screens if at all possible. Of those, I would probably go with the Thinkpad T series for the build quality, the Edge is a Thinkpad in name only and not nearly as well made.
If you are looking to stretch your dollar, I would highly recommend checking out the Lenovo Outlet. Excellent deals and you can even get new systems at a very nice discount. I've seen the Thinkpad Yoga S1 (last gen version of the Yoga 14 but smaller, 1920x1080, and some include a stylus) for as low as $700's. You can find T and X series Thinkpads on there all day long at good prices.
I purchased a Thinkpad x230t there almost 2 yrs ago now and had zero complaints with their service, shipping, and the quality of the unit thus far.
Good luck on your search!
+1 on no 1366x768 screens
i had one on my dell 15" and it was just hell, you can really only do ONE thing at a time, literally.
Not to mention the viewing angle was absolute crap.
1080p or at least a 900p screen should be your min target.
1366x768 is barely passable on a 10". Don't even want to think about it on anything bigger.
Thanks everybody, appreciate the tips.
I think I'll go with the entry-level Sager. I'm comfortable that the build quality will be good, and this should last for several years of daily home-office use. Good points on the screen resolution, and this is one of the things that has helped me decide more firmly on the Sager.
