Safe way to quickly test PSU
eli2k
A clip I saw online showed how to test a PSU without having it connect it to anything by shorting two of the pins with a paperclip, and attaching some fans or something to provide a load for the PSU. Another article mentioned doing this is not really good for the PSU. If I had to test it, I have to unplug cables from a current setup, so I'm wondering if the above method is pretty safe, or should I not risk it?
- Eli
You put one end of the paperclip in the green wire hole, and the other in any of the black wire holes. Flip it on, and the PSU fan should spin if its working.
Now, that will not tell you how it does under load though, or how the voltage rails are doing. For that you need a DMM.
Oh, and its perfectly safe to do it. I run mine for a day at time like that each time I change something with my water cooling to leak test.
Thanks. Good to know that you haven't had any problems with it. Just so I don't kill the power supply, I looked at the big plug, if I label the empty pin as pin3, then go across to the green/black wires, it's pin6 and pin7? Pin7 is green, Pin6 is black, but you said I can use any black wire, but just in case.
I never paid attention to the actual pin numbers, but there's only one green wire that comes from your PSU. All the black wires are grounds so they're all the same, but I usually use one right next to the green wire for convenience's sake.
I've done it multiple times to test hdds for spin up/ spin down.
Thanks, everyone. I just tested it out myself, PSU fan spins, the fans I attached also spin. Looks good!
