AtramentiA
- Oct 14, 2008
Been seeing this around a lot recently, seeming to come up due to the bad aftermarket cooling for the GTX 280, specifically, to which I just switched.
What is the highest safe temp range for the VRMs?
I'm having the same problem as I'm seeing others around having... my VRM temps are literally skyrocketing under load, and I've seen my VRM temps hit up to 80C using the HR-03 GTX. Apparently, there are a lot of others getting the same results.
I have more than adequate cooling in my case, and the temps will drop back down quickly, but when gaming I range between 65C-79C, depending on how graphically demanding the game is I'm playing. Idle VRM temps aren't even any different than the stock cooler offered.
Does anyone know what the actual max safe temp range is for the VRMs on the GTX 280? EVGA's site states over 70C is "normal", but like many other people I'm seeing more recently on a few different forums, 70C-80C seems way too hot.
As for a possible "fix"...
I checked another post here from just recently, and it made me think of a similar thing: what if you removed the pushpins from the plate, removed the cheap thermal pads and actually used Arctic Silver thermal adhesive to adhere the plate to the VRM chips?
AS thermal adhesive has worked wonders for me in the past on memory chips, so I cant see why this might not help...?
The plate that comes with the HR-03 GTX is very light, and though the chips are small, I think between all the chips it might offer enough over all surface room for the adhesive to hold, and should cool a hell of a lot better. I've a feeling this might work, but am afraid to chance it if it doesn't, because then I'll never get the pads back onto the plate.
I'm tempted to try, but before I do, if someone could tell me what is considered a safe temp for the VRMs and if pushing 80C is too hot, I'll know whether or not it's worth experimenting with.
Thanks in advance.
Thanks in advance.
